silverstone sg08 case
6 Apr 2014
I have a silverstone sg08 case and need some advice. Due to the size of this case with limited space and the 600 watt psu what would the best / most powerfull choices be for a graphics card? I do not intend to overclock the system and just want to include an i7, 16gb ram, 2 SSDs and a slim bluray drive. Any advice would be great, thanks
Tim
I just stuck an MSI R290 in there, and it was a mad tight fit. Though length was not a major issue as it's under 12.2" limit by a decent amount so there is space for the PSU cables.
It's just width wise a bit of a monster, I had to remove everything out of the case including PSU and almost brute force squeeze it in without damaging anything. Now it's in there I dare risk taking it out again!!! Also due to size was unable to reinstall the top fan if I want to put the cover on the case.
