The Silverstone Temjin TJ07 isn't cheap at > £220, but it looks like just the ticket for what I'd like. A couple of questions please to help me make my mind up if anyones got one or seen one:
(1) In the bottom of the there are a couple of 3.5" drive bay enclosures. I'm planning to watercool this box using probably the Alphacool 3x120mm radiatior. Assuming I can mount the PSU in the nearside hole (you can mount two at the back side by side), and take one of the drive enclosures out, will I be able to mount the rad. against the back wall at the bottom blowing air directly out the case at the bottom?
(2) The case looks nice and heavy (up to 8mm sheet ally apparently) which is fantastic as it should cut down on vibrations and that "tinny" feel of other cases. However there's no side window panel available. Could anyone tell me how thick the side panel is, and have I any chance of Dremmel'ing a side window into it?
(3) Whats the general build quality of the Silverstone cases like? I'm using a Lian-Li PC70 cases atm which is OK on the quality front - but given I paid for it a similar amount as the Silverstone case (albeit a few years ago now) I was hoping for something a little better (more solidly built).
Thanks in advance for any help you can offer for these questions!
