Silverstone Temjin TJ09 120mm Fans
31 Mar 2009
Basingstoke, UK
Not sure if this should go here or in the cooling forum, but guess it doesnt matter too much.
I have the above case, and planning a newish build/upgrade, so thinking its time I looked at setting it up properly by using the currently empty two 120mm fan slots at the top, and possibly getting a fan controller. So, I am looking for some advice on which ones to get, and also if they are actually worth getting. It does generally get quite hot in the room, and the comp itself will be mainly used for gaming.
