TheSwede said:Not the best of pictures but here is one..
http://www.tomshardware.co.uk/2007/06/06/computex_day_1_cooling_uk/page6.html
Cheers
Tom
Raikiri said:It's an ATC design, on steroids![]()
Looks like a 110-SX1 if I'm not mistaken.
Hades said:At last! I've been waiting for Silverstone to release something with a door. I've been a fan of the original 110 since it was launched. I bought it's baby brother the 111 and loved it for years until the cooling wasn't quite good enough with the 80mm fans.
Unfortunately I really don't like the side vents. The whole point of the door to me is to give it a smooth clean uncluttered look. But I may well have to get this despote those side vents.
Have you had a look at the TJ03? It's been out for a whileHades said:At last! I've been waiting for Silverstone to release something with a door. I've been a fan of the original 110 since it was launched. I bought it's baby brother the 111 and loved it for years until the cooling wasn't quite good enough with the 80mm fans.
Cybertronic said:Have you had a look at the TJ03? It's been out for a while![]()
It uses two 80mm rear case fans, I have a TJ03B myself and I doubt having a 120mm as a rear case fan instead of the two 80mm fans will make a difference because the front 120mm is quite restricted in terms of airflow by the front case doorHades said:Yep. Was very tempted by that. But it still has two 92mm (80mm?) rear fans rather than a single 120mm.
Cybertronic said:It uses two 80mm rear case fans, I have a TJ03B myself and I doubt having a 120mm as a rear case fan instead of the two 80mm fans will make a difference because the front 120mm is quite restricted in terms of airflow by the front case door![]()
tipes said:Hi,
Just bought the TJ09 - great case. The side vents might be a bit ugly to some peoples way of thinking - but they do seem to work as far as cooling goes. Shaved 4-5 deg off my cpu at load & also 6-7 deg off my gpu temps.
Depends what is more important to you, looks or performance - there is always a compromise somewhere down the line.
