||Silverstone TJ05/Akasa Mirage 62 with a 8800GTX||
26 Oct 2006
Hi, i have been looking at a case to get or my new rig but need to know if a 8800GTX will fit the following cases nicely (no extreme tight space):
Silverstone TJ05 (getting window mod too)
Akasa Mirage 62
i used http://www.tosk.co.uk/8800/ but it didnt ahve the above cases and saw similar stuff like the eclipse 62 but wasnt sure if dimension etc was the same.
Also although i ask only about these two cases i was also looking for advice on cases with windows. Nothing must obstruct the window like a design or something, the silverstone tj05 has one metal strip near the top but i can use that to place a uc cathode or LED's on. I want it to be a fairly good view of the insides but nothing too revealing.
Thanks Amrit
The mirage is identical to the Eclipse except the front is different.
So yes you can fit anything in it :)
The TJ05 should also fit it fine, being a eATX case (ie its longer than standard)
OO yay someones awake:D thanks for the fast reply mate it helped a lot.
Now its time to decide....Silverstone or akasa....
Anyone had any bad experiences with eitherof the boards?
ive now added them 2 cases to the list :)
if you know of any more cases please list them.
The TJ03 can fit gtx and gts (assuming cos it can fit gtx it can fit gtx), someone in the forums ahd a pic of it.
