Silverstone TJ06 and double radiator
Permabanned
20 Apr 2004
Far far away....
Does anyone know if you can fit the double rad of the switec kit intothe front of the Silverstone TJ06 case.
Im pretty sure I can remove the plastic housing for the 80mm fan that is alreadt there but Im not sure if there is enough space height wise to fit it.
Thanks!!
where abouts to you want to fit it?? best way is to take measuements if you already have the case, and you can get rad measurements from manufacturers site, most will have a printable template to
i cant find any dimensions for that space online, but by the looks of it there is a 120mm fan at bottom and if you remove the floppy bay then i reckon it will fit fine
