Silverstone TJ07
21 Feb 2007
I'm really fancying a TJ07, it looks stunning and seems to be really popular with all the high end 'Dream PC' manufacturers, but it rarely gets a mention in this forum. Any particular reason why? Something wrong with it that i'm not aware of maybe?
It's simply because it costs £205 which is obviously super-expensive for most people. And the fact that OcUk doesn't stock it. The only thing I don't like about the case is the twin rear 92mm fan mounts; slightly annoying. But other than that, its arguably the best mass-manufactured PC case on the planet.
Yup, I bought one last week. Absolutely stunning case. I got it in black with the window panel and I just can’t wait to buy all my parts and install some sweet water cooling. The twin 92mm fans on the back arent a problem at all if your intending to water cool. There's 2 120mm fans above too. You can literally strip the case to suit any need.
I'd say get the case as it really is worth the extra money and if you’re into water cooling then you won't need to mod it at all, hence the reason why I bought the case. Plus is looks superb. If you want to drop me an email at mark [email protected]
I can tell you where I get mine from. Ordered and got it with 24 hours.
RoEy
RoEy
hi mate, any chance you could post some pictures of your case? i'm seriously considering getting one in black.
Fantastic case. I was very tempted to purchase this myself but alas the price and my budget got the better of me. If you have the cash get it.
I ordered a Antec P182 from OCUK instead.
:) My Silverstone TJ07 case :)
The TJ07 (and to a slightly lesser extent, the TJ09) are amazing cases. I'll never afford one mind you, but I do like drooling at the pics :)
Stunning Chaparral :)
:) Thanks :)
My case is far from being that clean now...Most them pictures were taken about a year ago...
Am going be stripping the case down to nothing and giving it a good bath when i next upgrade the motherboard or maybe when i upgrade the GPU...
and replace all the watercooling hoses and maybe all the fans as well..(I normally replace the watercooling tubes about every 3 to 6 months)
Well everyone would have a Ferrari if they were £15,000.
Lovely case what I dont understand is why the 2 rear 92mm are intakes wouldn't they be better as extraction ?
:) I normally replace the watercooling tubes about every 3 to 6 months)
Bit too often aint it? If you use the right solution i.e. Feser 1 and some tygon tubing it will last for years.
Lovely pics though mate. I've got the same case and I can't wait to start building with it. Looking into powder coating mine though. Anyone had this done before?
RoEy
