Silverstone TJ10 Case - Rad question...
18 Oct 2002
Fife, Scotland
Hey there,
Im looking into another case, but im going to need a decent case for to transplant my watercooling gear.
Can this case fit the Thermochill PA120.2 rad including fans up on the top corner, using the radiator support brackets?
Hopefully someone has this case with watercooling installed :)
Hey there,
I can check this tomorrow for you, It will take a 30mm thickness rad + fans though, using the 4 middle screw holes to mount the rad to the metal plate that goes between the stock fans ( if that makes sense )
I think you can buy a 120.2 bracket for the top section. see their website
sid
[Edit] Just realised the part you were talking about... spacing for thermochill rads ( space between fans) is different from any other rad, as is the thickness.
Cheers for the replies,
I managed to find this picture today...
Wondering how accurate this is and if its really possible without having to cut away at the case, after all i dont want to hack up a £250 case lol
What is the size of the grill on top? I don't want to cause people too much grief :)
that picture looks to have had the standard metal brackets removed from it.
In the top of the case there are metal mounts that the plastic fan holders bolt too.
Ordered the case now, along with a few other things :)
From what i've found out i shouldn't have too much of a problem fitting the gear, ill report back if it was possible to fit without issue. Roll on Monday!
Trox
Only thing with that setup is your be filling your case up full of hot air - not good.
Yea, that was one of my concerns.
Ill see how it goes, i have the rad mounted externally at the moment so that is always an option for me.
Ive seen setups with the rad mounted on the top and they seem happy with it so... *fingers crossed!*
