Simfree phone for around 100 notes?
Caporegime
18 Oct 2002
Lake District
Looking for a new phone that has at least a camera on it, buying new or new from the bay is an option, the phones I've looked at are the Samsung D900 and the Sony W810i, but I'm really not up on phones so I don't know whats best!
Any suggestions?
Best phone AFAIK under £100 is the SE K750i.
I have the D900 and the K750 and the camera difference isnt that great.
The K750 has a better flash too.
I'd get the K750, its cheaper than £100 aswell.
Why Simfree?
Surely if you got it with a PAYG SIM on the same network as the SIM I assume you already have and want to use, it will be cheaper as it will be subsidised unlike a SIM free model...
Yeah I've since realised it's cheaper to have it locked to a network, in my case it needs to be Vodafone.
I believe that the W810i is just the same phone has the k750i, but flashed with better firmware (better media player?). k750i also has a lens cover, w810i doesn't. With some of the earlier k750i's, you can flash them with W810i firmware.
W810i comes with a 512MB memory stick; K750i only has a 64MB stick i think.
k750i can be picked up brand new on Vodaphone for £80 delivered.
W810i is £50-70 more. (£150 on vodaphone)
I've been looking at k750i or w810i, and on some shops it looks like they are discontinuing the W810i.
K750i, you get a better deal, but if you want to buy a memory stick then it's +£20 ish, so w810i is £50 more for a later phone that looks better. Possibly get the w810i cheaper though.
