simple advise needed
16 Sep 2012
Hello guys i currently run a asus gtx 660ti 2gb card i play fps @ 1080p wondering what card i should go for next ive been looking at 760 and 770 purely because they are in my max price range £300 but i am getting the SAME if not slightly better fps in BF4 THAN MY FRIEND WITH A msi 760 so i need help i want a card that i will see the difference from my current one cos if not why upgrade lol any help will be great
Whats your budget? One of the new AMD cards it's probably your best bet. More bang for your buck.
What are you getting in BF4? I have a 660ti :D
not sure of his cpu tbh i get 120fps everything low hboa ect turned off im getting between 63 and 84 fps in game on floodzone i have had fps drops to 54 thats ultra with no lightning affects off and hb/b ottom 2 affect in options turned off
It's your money, but not sure I would upgrade to either of those options.
I would look at the AMD offerings in that price bracket mate or SLI the 660..
Well, you might be looking at something like +10-15 increase in average FPS if you would go for a 770, ain't particularly a fan of this site, but it can sometimes give you a "rough" estimate of what you should expect: http://www.anandtech.com/bench/product/860?vs=829
Tbh, at that budged, I would say R290 if you want to see some real performance increase, since anything on the green side that would give you a decent increase is quite a bit over your max.
