Simple and unbranded FLV player/flash embedding
27 Dec 2005
Bristol
I'm looking for a simple FLV player to embed flash banners with. No skinning/timeline etc required, just the video on repeat.
Can I just use Adobe for such a thing, and if not what else can I use?
FLV is a video format while Flash banners are generally SWF.
Any adverts which are done with FLV are probably embedded with a custom player made by the advert company.
However, if you're just wanting to drop in a normal swf flash file, check out swfobject.
