I have a set of strings, which are made up of a string and integer.
For example:
Dave5103
This is stored in a char[], actually... there are a lot of them and they are stored in char[][], but that won't affect the solution.
I am looking to pull two bits of data from this, the string, and the integer.
Is this possible? If it helps, I can change the format of these to:
Dave-5103
I'd really appreciate any help with this.
Thanks,
For example:
Dave5103
Dave-5103
Thanks,
