Simple charge/sync dock for iPhone that accepts an adaptor... ?
4 Dec 2006
Hertford/Portsmouth
I have an iPhone 3G with a capsule neo case that also came with a dock adaptor so that you could use the iphone in a dock with the case on, thing is, I am struggling to find a simple adaptor that accepts this adaptor...
I dont want a music one or anything like that, the simple white iPhone one is all I need, though from looking at ones on fleabay, its hard to tell if you can change out adaptors in them,
is this anything I need to be searching for ? or is there a name for them ? Universal helps, but ones I do find that have changable adaptors look different, and it doesnt look like my adaptor will fit...
anyone happen to one the right one I should be looking for ?
You can't change the iPhone one but a normal Apple Universal Dock will take it. That is if it's designed for the Universal Dock, which it will be, 99% of all iPod accessories have it.
It's standard universal dock size so it'll fit in anything that says that.
