All,
I have a faulty Cisco switch at a remote location.
The remote location has several switches, and i need to replace the faulty one. I want to copy a config from one of the working switches and edit the IP/Host.
This will save me configuring from scratch. What i want to know is, can i export the config, and then load it onto the switch on my desk via Hyperterminal or something?
Thanks all
Thanks all
) make sure you delete the "ntp clock-period" line in the config you strip our of the exisiting switch.
