Simple CPU Loop Spec.
27 Jun 2005
Reading
Hi guys
Thinking of doing a simple CPU loop, your thoughts on the spec below?
Cheers
The one you linked was the one I bought to cool an fx8350. How good it is I dont know but I know it did kerp my 8350 below 58c with a 5ghz oc on it. I also upgraded the loop to include a 7970 and a phobya 200 rad so the pump/bay combo did have a good bit of power. Temps in full loop gaming was 50c cpu and 43-45 on gpu
Ex rads are out of stock right now.
Either wait or swap it for koolance hx 240.
Good rad with good stats, a lot of fpi.
Its thicker than ex though so check if it fits your case.
