Simple Excel help
18 Oct 2002
Heaven
Hi there,
What I am trying to do is this ( hope i can explain it easy):
Column A : insert figure ie 20 (format as money)
Column B : Add 17.5% (add the vat)
Column C : Add 20% to the sum of column B
what i tried is: in column b =sum(a1+17.5%) when using the figure 20 but it gives me 20.175 instead of 23.50
What am i doing wrong?
Cheers
Gas
When working out VAT I normally do something like =SUM(A1*117.5%). You are adding 17.5% whereas I think you need to multiply by 17.5% or 117.5% in order to reach the VAT target.
A1+17.5% is just doing A1+0.175. You need to *1.175 or 117.5%, as said above.
Similarly, to add 20% in column C you need B1*1.2 (or B1 * 120%).
You didn't need Excel help, you needed Maths help(!) :p
Blimey!! I got a maths question right?! I'll have to ring my Mum; she won't believe me though.:o
Thanks for all your help,even though some of you are abit cheeky :D must admit maths was never my strong point at school and i left 17years ago !!!
Gas
