- 17 Jan 2006
Hi All
Where I work we use some online database software and want to send out a bulk email. In the past the only option we have had to make anything look nice is to produce a pdf and attach it to the bulk email.
Recently the people that provide the software have added the option of pasting html into the bulk email (wow....the future is finally here...)
As such I'm in the process of putting together a very simple html newsletter which I am doing in frontpage as it is either that or trying to use a really simplistic and awful browser based editor...
I'm keeping it nice and simple in the hope that it'll display ok in most email programmes.
To keep things lined up ok I'm using tables which are set to 640 pixels wide as that is the maximum width of images that can be uploaded to the database software. This way I can use a 640 width image as a banner header...
Anyway, the newsletter is basically a series of short articles with a single image for each.
The images alternate son for one story it'll be aligned on the left and on the next it'll be on the right.
To do this I've put each story into a table with 2 columns and put picture in one column and text in the other.
However when I'm previewing it, the images which I have put in the right hand column and set to align right are displaying too far to the left not all the way to the right of the table as I want them to be as you can see below.
The image I've marked as 1 should be aligned over to the right, ie level with the green line I've helpfully added...
The image and the text are placed into a 2 column table set to 640 pixels wide. The text on the left is in a cell which is set at 384 pixels and aligned left and the image is placed in the right hand column set at 256 pixels wide and set to align right...
Can anyone explain why this is happening or how I can sort it out?
Valve
Valve
