- 20 Jul 2007
- A sunnier or damper area than Ron-ski....
Ok, wanting to achieve something seemingly simple I hope....!
1) have a TV in bedroom with an electric mount
2) it has two IR settings on its remote: open and close
3) unfortunately, given TV mounts appear to be frozen in the mid-1980s, the only connectivity is IR remotes, so I'd like to get it connected via WiFi so I can use Google home etc
I've tried a switchbot, which just doesn't work properly - possibly because it doesn't connect to a 5ghz WiFi (it seems to connect fine, but is just sporadic and erratic) and loses connection constantly.
Can anyone advise on a good solution for this - don't really want to spend a huge amount given I'm only using this to open and close a mount, but want something that will perform this task reliably...!
Any help much appreciated!
