Simple mesh WiFi...
18 Jan 2007
Dorset
Hi all, hoping for a little advice. Presently with Plusnet and their 900mb package, and I'd like to improve on the supplied routers coverage without spending a fortune.
Is the TP-Link Deco S4 AC1200 worth considering ? It appears to do what I want and at around £100.
ive installed a few they all work really well, dont forget you will need at least 2, 1 to plug in with an ethernet cable to your router and one mid way to extend the mesh...
1 ) they take an age to reboot if you have issues setting it up just wait 10 mins and revisit it
2) they default to dhcp enabled / router mode, i always change them to "the otehr mode" to they jsut use the existing routers DHCP)
they have been very reliable
My default response when a family member or friend complains about poor wifi (and it's actually the wifi) is to suggest they buy/throw a 2 pack of DECO's at them. The downsides (and most of them really aren't) are as follows:
It's app managed rather than browser, so in the unlikely event TPL dropped the ecosystem, you are screwed.
You can only have main/guest/IoT SSID's.
It manages the channel etc. though in fairness, it seems to do a reasonable job.
No VLAN support.
More hardware revisions than seem reasonable - partially down to supply chain issues during plague times.
Updates aren't consistent - some models get an update, others don't, same with some hardware revisions of the same model.
Can be quirky with upstream switches, won't play nicely with my Aruba for some reason, but the generic TPL and Chinese switches are fine.
Usual mesh rules apply, hard wire them or accept less than line speed - at one point during a downstairs refurb I had to run a pair in bridge mode to my router, they still managed upto 800mbit node to node between floors. Other than that, they're basically fire and forget with easy management, diagnosis and painless automated updates that don't generate any further calls for help. I've lost track of the number I have installed, but we have four here and i've got 5 other sites running them off the top of my head now. This is based on the X20/50 generations, although one of those sites has an older AC1200 version supplied by the ISP, I personally wouldn't bother with anything that old, it's not priced significantly differently to the X series whenever I have been buying.
Question: can you use the ethernet ports to connect wired devices at the end of your mesh? Eg. Have some non WiFi devices in rooms I might put Decos in.
If you don’t have enough ports, you can add a switch, the only consideration in doing this is that you have a single gigabit backhaul that may be a potential issue for you, but all local traffic between clients on the node/switch would only go locally without using that backhaul link.
Like Dyson, I've gone for a set of S4s, used at £50. We can compare notes :D
Loved the S4 for coverage (game changer) but picked up a dirt cheap set of P9s (basically same with Powerline AV1000 built in to supplement). So sold the S4s for no loss and I'm VERY happy..... Deco just works
Got Deco P9's in our house and my parents. Just work. Powerline works well for us as we've got external walls in the house due to an extension. No its not as quick as hardwired and I'm sure there are a lot quicker options out there but for wat we use it for its absolutely fine. Only issue I had is when I'd ignored some updates and they went a bit flaky. Updated andwere fine again.
