Simple PHP Variable Woes
31 Oct 2005
Leeds
After taking advice from IIRC DJ Jestar about using the glob function I have ended up with this
PHP:
		<?php
  foreach glob("'$d_no'.JPG") as $file) {
    echo '<td>' . "<a href='$file' target=_blank><img  src='$file'  alt='$file'  width='220' height='220'></a>" . '</td>';
echo '</table>';
Now the above works when I use
PHP:
(glob("'7.JPG") as $file) {
However I'm trying to use the variable $d_no, which when echoed on that page displays fine, however if I used the first piece of php code, globing the variable $d_no, I'm met with
"Warning: Invalid argument supplied for foreach() in /home/irgscouk/public_html/userpage.php on line 61"
I'm sure it's just the way I'm declaring my variable
Any ideas?
Be sure to know exactly what is being sent to glob..
PHP:
$d_no = 'foo';
echo "'$d_no'.JPG";
this will output:
Code:
I'm not sure you want that?
Think you're after:
Code:
foreach glob($d_no . ".JPG") as $file) {
and see Jestar's explanation about mixing quotes.
basically in the same directory as this php script I have a few images
2.JPG etc etc
I want the relevant picture to be displayed upon the choice of the variable
As I said, if I MANUALLY say, display Just 2.JPG, its fine and happy
If I say, dynamically display that variable.JPG, it's not happy
Jestar, I'm using the variable d_no on other things on that page, and they are coming out fine
The variable is definately The number asked
If you only want a single file, whose name you already know, then why are you looping over glob? :confused:
Surely this does exactly the same thing:
PHP:
<?php
$file = $d_no . '.JPG';
echo '<td><a href="' . $file . '" target="_blank"><img  src="' . $file . '"  alt="' . $file . '"  width="220" height="220" /></a></td>';
echo '</table>';
Also, just to be pedantic: TD elements should be contained within TR elements in HTML tables.
no no, I was looking for a file where filename = variable
my point was it wasn't working as I was declaring my variable wrong
The other point was that the script was working due to the fact that if I MANUALLY declared a file, like 2.jpg it worked so I knew it was how I was declaring the variable, hence the thread:D
Anyhoo it's all sorted now
