Hi I'm looking to get a really simple countdown programme made. I've tried making it myself in VB but I haven't programmed in about 6 years and for what I want it's not worth me learning everything from scratch again so if someone could help me out I'd appreciate it.
Basically all I want is a little exe app with no install or anything necessary, open it, there's an input box for how long you want (say 2 minutes) and then a go button, when it runs out it plays a noise. I have a noise I'd like so that will need putting in, it's only a 2 second long wav file, is there anyway to incorporate that into the exe? When i was messing around with VB it was all string functions locating the fil and whatever, if I put it on the radio's computer then then destination will be different from my computer.
Can anyone help me out? For a half decent programmer I can't see it taking more than 10 minutes.
I need it for my radio show for when I do quizzes and things so I'd appreciate any help.
Thanks
Thanks
