Simple PWR_LED question
17 Jan 2010
Hi Guys.. probably a very simple question but my Mobo has a 3-pin for the PWR_LED but my case is only 2. Can I just connect the 2 leaving one out or do I need to do something else?
Cheers!!
I have had this a lot in the past and usually just use a set of side cutters and put them on individually. a lot of new cases either come with a 3 pin header with 2 wires (One at either end) or 2 seperate connectors.. Just remember as a rule of thumb is that the coloured wire is "Normally" The pos.. :)
Some cases only come with hdd led's, take the antec 900 and 902 for example. i made my own power led for my 902 from an old case.
