Simple question, hopefully a simple fix
27 Aug 2011
Sheffield, UK
So I've got the system listed in my sig, recently though I seem to be getting more and more black lines/flickering on my monitor, it only seems to happen why I use Overdrive to overclock my card.
At first I thought it was a lose cable, but I've checked all those, then I thought it was because the card was being underpowered, but I've tested that too.
Any ideas how to fix it?
Use another software to monitor temps and set overclocks. See if the issue is to do with the software.
I've already got CPU-Z, real temp, core temp and CCC the temps are fine, I thought it could be a loose cable or the monitor cable resting on the power cable, but still no luck
