Simple question?
3 May 2012
Far away
Hi guys,
About to replace a heatsink but want to put new thermal paste on for a laptop and just wondering if i can use my Artic Silver 5 that and if i can how much do i put on as i have noticed the CPU is smaller than i5 processor.
Thanks
Same principle, just quite a bit less paste, you don't want it to leak too far over the CPU die (shiny bit). Sometimes less is more, particularly in direct contact between CPU-Heatsink
Thankyou!, i know it's a nooby question but it's better to be safe than sorry! :)
I've seen loads of laptops that have far too much paste applied, and that's from the factory! - it really is just a tiny surface area that makes contact
I did notice an excess amount of paste on this one too that's what made me curious, but i'll do the same procedure as all other CPU's and i can't go wrong :)
