Okay, this is a plain and simple question about RAM for which I always forget. Say for example you have four modules of RAM of the same make and model. The CAS on each module has to be identical to the first... say for example, 9-9-9-24 all the other modules have to be the same otherwise there can be complications and the modules will not work in conjunction with each other.
I’m I sort of on the right track of slightly off the rails.
Thanks in advance.
Thanks in advance.
