Simple setup help and advice – Livebox / Netgear.
26 Feb 2004
Hampshire, England.
Hi guys,
A family friend has been using an Orange Livebox for a week now, despite going against my advice and signing up to another 18 month contract with them, but anyway. He’s set it up okay and thought that it could totally replace his trusty Netgear DG843G on his small home network. However, the wireless on the Livebox doesn't appear to like his Mesh laptops… if he does connect, it drops off within about 20 seconds, but most of the time the Laptops can’t even see the Livebox.
My suggestion is to use the Livebox as a sort of stand alone DSL modem and then he can also use the free phone calls thing that you get with Orange. I intend to disable everything else; DHCP, wireless etc, so as to avoid any conflicts.
Then I should be able to just plug the Netgear into the Livebox and use the Netgear for wireless and DHCP. Does that make sense? Have a look at my diagram; sorry for the bad quality, it took me about 2 seconds to do in paint :p
http://g.imageshack.us/img443/31379091bw2.jpg/1/
He also mentioned that the file sharing he has between his Vista desktop and XP laptop didn't seem to work with the Livebox in place, hopefully going back to the Netgear will sort everything out :o
I'd appreciate your thoughts guys.
Cheers,
SW.
File sharing issues between vista and XP is a software problem. Have a search in the windows forum for that. All sorts of things can cause that not to work.
I spent about 2 hours yesterday evening trying out all kinds of things, trying to get the pictured setup to work... didn't manage it tho :rolleyes:
I've got the Livebox with me atm, I'm going to have a play with it on my network.
Sp00n: both bits of kit are on the same subnet, 255.255.255.0, but they couldn't seem to work together? I couldn't ping the Livebox from the desktop, which was directly connected to the Netgear. I got a reply from the Netgear (192.168.0.1) saying that the Livebox (192.168.1.1) was unreachable :(
For now, our friend is happily back using his Netgear for everything, and it is completely trouble free. That's including file sharing - I set everything up a while back and we've never had a problem between Vista and XP?
SW.
