Simple slot design - Any P'shoppers around ?
Man of Honour
16 Mar 2005
Clevedon , Bristol
Hi.
Looking to make a front panel for my case , but need to some help with the design.
The idea is to use this " style " :
The wording " murderbox " will be replaced with " Dark Water " , but i need to change the styling of the slot cuts so it doesn't look like a straight copy.
This is the size of the panel area below the DVD drive rectangle near the top :
Can anyone lend an idea , or two ;)
A PSD would be a bonus :D
Thanks for looking.
Mark
Do your dimensions include the bit with the drive slot in it? As that front facia looks like one piece? Also, I assume those front slits are for air intake?
Hi Gord.
The dimensions DO NOT include the DVD drive slot area , this is the free space below it.
Its actually 276mm from bottom of drive slot to the base.
And yes , the slots would act as some sort of intake ( or to let light out ) , would probably only be 3mm thick slots.
As you are using dark water on the case, why not look at getting some sort of fluid ripple effect, like someone dropping a stone in a pond?
