simple SQL help...please
6 Oct 2007
Liverpool
Doing coursework and on creating a table am stuck for what data type Hieght would be....
simply 'integer' or 'decimal[((precision[,scale]))]' or 'float'
any ideas?
Ok seem to be ok with that...thanks
I have had a good route around but cant seem to find a solution for
Error Code : 1062
Duplicate entry 'P111' for key 1
(0 ms taken)
apparently it means i ave 2 entries under 1 primary key... but i dont?!
I have 'P111' (the data) as a primary for table X
and P111 is also data entered in another table (table y) but not under a primary key.
would this be the problem though... I am sorry if this is hard to understand bit of a beginner.
thanks
