Simple SQL question
18 Oct 2002
Bit of a mental block here, but basically I have 2 tables, I want a query to select all records from table A that are NOT also in table B. How is this done?
Thanks
thanks truz I figured out your way, now its giving me this
Parse error: parse error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING
for this
$sql = "SELECT * FROM courses WHERE level = '$_SESSION['user']->level'
AND courseID NOT IN (SELECT courseID from subscriptions
WHERE userID = '$_SESSION['user']->userID')";
$result = mysql_query($sql);
meh, i should go to bed :/
edit - fixed that, but the query gives no output, meh :/
edit - fixed
you can do it with a sub query like above and it will will work and give you the correct results but be warned it is not the most efficient way of doing it is with a left outer join...
http://en.wikipedia.org/wiki/Left_outer_join#Left_outer_join
most modern DBMSs will optimise the query above in exactly the same way as a left outer join syntax anyway though so it probably doesn't matter too much.
Paul
