Ah, that rings a bell. Many thanks.Furmark, the end.
You can use this browser test if you want. It's fully customisable.Ah, that rings a bell. Many thanks.
just be careful, it is very easy to get distracted, and forget that it is running, and furmark creates a lot of heat, really stressing the card, easy to break one, esp if you are overclocking itAh, that rings a bell. Many thanks.
Brilliant, thanks.You can use this browser test if you want. It's fully customisable.
https://webglsamples.org/aquarium/aquarium.html
Thanks for the tip. It’s not overclocked, but something in my system is causing issues (black screen after some light gaming, PC has to be reset).just be careful, it is very easy to get distracted, and forget that it is running, and furmark creates a lot of heat, really stressing the card, easy to break one, esp if you are overclocking it
Hmm, what's the card?Thanks for the tip. It’s not overclocked, but something in my system is causing issues (black screen after some light gaming, PC has to be reset).
I figured I’d check the card using a simple test first before I look into what else might be causing my problems.
That, Furmark unnecessarily stresses a card and is just not needed.Unigine heaven or superposition
Yep stress test / Power/ heat virus, good in the winterFurmark it is
