Simple to use system restore software?
13 Feb 2004
Sealed in my Sarcophagus.
Not sure if what i want exists!
I am building a full pc to sell with a genuine windows 7HP installation i will be doing manually. I want to set it all up with drivers and updates etc and then create either a restore partition or restore dvd/memory pen the buyer can use to simply boot off and almost auto restore back to "factory".
Does such a software package exist?
A few of the free ones require you to boot the recovery program first and then point it at a file that could be on a flash drive or other disks (Swap it out) They are free and easy to use like macrium reflect and Aomei backupper. However i think they strictly prohibit commercial use.
Well its not commercial as such just selling my own property :p
As it happens i may have a buyer who is tech savvy so its probably not needed now.
Macrium Reflect, Aomei Backupper, Acronis True Image 2015 and Windows 7, 8 and 10's System Image Backup cannot created bootable recovery partition but they can only created system image file and stored it on hard drive or other partition then used created recovery media to booted PC and pointed to system image to restored PC fully but if system image is anything like over 100GB then it wont fit in USB stick or required so many DVD disks.
If you want similar software OEMs used to created bootable factory recovery partition then yes there are software existed that can created bootable factory recovery partition to restored PC to factory setting so here are very few software like AOMEI OneKey Recovery and ANARETHOS RECOVERY TOOLS with MEDIA CREATOR.
http://www.backup-utility.com/okr/make-a-recovery-partition.html
Above link included guide with pictures how to created bootable recovery partition.
http://forums.mydigitallife.info/threads/21978-ANARETHOS-RECOVERY-TOOLS-with-MEDIA-CREATOR
http://anarethos.com/recovery_W7W8.html
Anarethos site has user guide with step by step guide how to create recovery partition.
