Simple upgrade, possibly to run 3 cards?
27 Feb 2013
Hey guys, I am really in the market to upgrade my motherboard just a little bit as I would like to run two possibly three gpu's instead of my single nvidia gtx 460 that I currently run. To be honest, this is more of an aesthetic want than anything having to do with performance as I hardly game. I have played about 2.5hrs of battlefield 3 in the last couple of weeks...I more or less browse the internet and do homework and my current gpu is fine for what I do (I am stating this so that I don't get the "you don't need more gpu's/what are you wanting to do with three gpus? etc).
So my plan/hopes are to buy another gtx460 or a set of 460s (will be buying used) and install them in addition to my current card, however my current motherboard doesn't support more than one gpu. I have the asus m4a87td/usb 3 and AMD 950BE Phenom II that I purchased in the middle of 2010 so I would like a decent upgrade.
What would be a basic (not over the top) motherboard suitable for my wants? Possibly 3 gpus? Also, and this is going to sound incredibly noob-ish but I have never ran more than a single gpu (as this is my first ever custom computer that I built back in 2010) how hard is it to plug in another gpu? Not in terms of the installation but compatibility etc? I mean if your motherboard supports it you can just "plug and play" another compatible gpu and the computer recognizes it or what?
Currently have a nvidia gtx 460 and would more than likely only buy an evga 460.. would these two cards work together? Would there be a noticeable increase in performance?
More than likely would like a mobo capable of 3 way SLI (hope I used that term correctly, I want to use 3 gpu not 6 ha) I know this sounds very dumb and these questions probably make most of you leet computer geeks rolls your eyes but hey we have all been in this boat before right?!
Thanks for the patience in advance and I hope I didn't ramble on too long
sorry for v. late reply, but my opinion:
if you want Tri-SLI purely for aesthetics, I'd say get three of the EVGA GTX 550Ti's, can be found very cheap - sadly not on overclockers however. AMD Xfire will most likely be cheaper also
Cards like the GTX 460 and GTX 550Ti only support 2 way SLI.
You're potentially going to run into CPU bottlenecking problems with appropriate cards in triple SLI.
