Simple vista qestion.
5 Jun 2005
Southampton
when i try and copy files to the c drive, it asks me to confirm, this is stopping me copy a SQL database over and churning up an error, anyone know how to turn this off, i don't use vista just playing with something
will try that chris, and here is the other way that i found incase anyone wants to know
Enable or Disable UAP/UAC:
1. Click Start
2. Click Control Panel
3. Select System and Maintenance
4. Click Administrative Tools
5. Double-click System Configuration
6. Click Continue (if prompted)
7. Select the Tools tab in the System Configuration window
8. Here you can choose Disable UAP or Enable UAP from the bottom of the listbox
9. Click Launch
10. Reboot to see effect
If you use Tweak UAC and use silent mode, it doesn't disable UAC completely, so you still have IE protected mode etc but you don't have the annoying prompts as an admin.
Burnsy
Burnsy
thanks chris, i just downloaded it, surprised scc did not block it!
by the way i have a little exe file that gets around the firewall if you want a copy,
