Simple watercooling!
3 Oct 2007
Ok, this may sound useless. But I have a Lian Li case PC7+, everything run at stock and not bothered about Overclocking. However, the fans of the case are really annoying me, the PC is on most of the time and I have to put it into sleep mode in order to play PS3 or watch TV.
I have no idea about water cooling, but can you actually have one, that only cool the inside of your case, without worrying about GPU and CPU blocks.
How much would it cost? I have no idea what I need.
If you can help. Would appreciated it.
The common misconception is that watercooling will make your system silent.
This is wrong.
Watercooling still requires some fans(on the radiator) unless you go for a passive setup such as the Zalman reserator. You will however still need minimal airflow through your case to cool the GPU, chipset and mosfets.
If I were you I and performance watercooling is not required then go for something like the Zalman and get a couple of Yate loons or akasa amber fans for the case and use some Akasa sound deadening material inside the case. This should quieten down your case a hell of a lot.
So you are suggesting to just replace the funs? I don't really need watercooling if there are other alternatives, because as I said. I ain't gonna overclock anything.
Replace the fans and change the stock aircooler to something like the thermalright ultra or the scythe ninja. Something with a large surface area that dosn't need a powerful(noisy) fan.
