Simple way for remote shutdown in XP?
15 Jan 2003
South East
What is the easiest way to perform a remote shutdown on a Windows XP machine on a LAN without having to be setup with specific accounts?
I want to be able to switch off a pc (after it's supposed to be turned off by my younger brother) but I want make sure nobody can stop the process.
A Scheduled task would be ok if it were not for the sake of weekends/holidays. I don't often access the pc physically as a) I can't be bothered b) I've stopped all ability to download from the internet and have automatic virus/spyware protection setup (only last checked 2 days ago) hence a).
It's more for the occasion when he's purely acting up that I can just flick a switch my side and he won't know the difference.
providing you have a user account (admin rights) on the machine you can do the following:
Start | Run | Cmd
type "shutown /i" (without the quotes).
Add the machine name, and hit shutdown. Works great, i use it a lot to shut my machine down from this laptop because i'm too lazy to get out of bed :p
KoR said:
shutdown -m //ipaddress -s -f
will do it.
Access is denied
Start | Run | Cmd
Microsoft XP remote shutdown
That is what I checked out before. I'd prefer not to have to make accounts between the two though I may have to do so.
Don't think there'll be any other way to do it. I suppose you could always set the administrator accounts up to match one another, providing he doesnt use that one (i.e. he has his own account). That might work.
you can do it with pstools from sysinternals using the psshutdown command.
It allows you to specify a username and password so you dont have to create an account.
http://www.sysinternals.com/Utilities/PsTools.html
You can use PsShutdown to initiate a shutdown of the local or a remote computer, logoff a user, lock a system, or to abort an imminent shutdown.
usage: psshutdown [[\\computer[,computer[,..] | @file [-u user [-p psswd]]] -s|-r|-h|-d|-k|-a|-l|-o [-f] [-c] [-t nn|h:m] [-n s] [-v nn] [-e [u|p]:xx:yy] [-m "message"]
the sysinternals tools are free.
