21 Jul 2012 at 19:47 #1 Skeeter Skeeter Caporegime Joined 8 Mar 2007 Posts 37,146 Location Surrey Whats the simplest way to rip a Blueray to a file? I could rip to a BD image, but I don't fancy giving up 25GBs per disk to backup my blurays. Is there any software that will rip a bluray to a file with a single button press?
21 Jul 2012 at 22:13 #2 KIA KIA Man of Honour Joined 14 Nov 2004 Posts 13,868 Do you want to strip the DRM? http://www.slysoft.com/en/anydvdhd.html
22 Jul 2012 at 01:22 #3 Meatball Meatball Soldato Joined 12 Jun 2005 Posts 6,360 Location St Albans MakeMKV.
22 Jul 2012 at 03:30 #4 Deep Deep Soldato Joined 29 Jul 2004 Posts 6,666 Location Esher Meatball said: MakeMKV. Click to expand... +1
22 Jul 2012 at 10:58 #5 Skeeter Skeeter Caporegime OP Joined 8 Mar 2007 Posts 37,146 Location Surrey Meatball said: MakeMKV. Click to expand... Doesn't that produce like a 50GB file though?
22 Jul 2012 at 11:14 #6 welshdragon welshdragon Soldato Joined 28 Dec 2009 Posts 6,893 Location Wales Skeeter said: Doesn't that produce like a 50GB file though? Click to expand... Then something like handbrake to re-econde it
22 Jul 2012 at 11:26 #7 Skeeter Skeeter Caporegime OP Joined 8 Mar 2007 Posts 37,146 Location Surrey welshdragon said: Then something like handbrake to re-econde it Click to expand... Is there anything that rips and re-encodes in one go?
22 Jul 2012 at 11:27 #8 Deep Deep Soldato Joined 29 Jul 2004 Posts 6,666 Location Esher Not necessarily. If you select one audio track and one subtitle track then you wont have that problem. I can give exact figures but Dark Knight blu ray is 26.2GB, and Avatar is 36.3GB
22 Jul 2012 at 14:05 #9 BloodyL BloodyL Soldato Joined 18 Oct 2002 Posts 3,083 Location In here and out there. Freemake video converter or Ripbot264
23 Jul 2012 at 00:06 #10 Meatball Meatball Soldato Joined 12 Jun 2005 Posts 6,360 Location St Albans Most of my blu-ray rips via MakeMKV are 18-25GB .
23 Jul 2012 at 14:47 #11 xtremedetailz xtremedetailz Soldato Joined 16 Jun 2010 Posts 3,445 Location Manchester Yeah I'd also like to know how to get the sizes down on a makemkv rip? Without loosing quality if possible.
