I am trying to install the sims 3 on my other computer for my sister.
Everytime I run the installer it says "are you sure you want to completely remove the application.. etc" before I get chance to select anything else.
So I said ok to remove it, then ran the installer again, asked me to remove it again.
It did look like it was installed before or atleast half installed. It had a directory but no application to run it.
I've done everything I can to "uninstall" it, removed via controll pannel, used uninstaller, deleted all sims 3files I could find with search and even deleted all the sims 3 registery files.
Rebooted the computer after I did all that and same problem, I even uninstalled sims 2 aswell incase that was conflicting with it.
But now I'm stuck.
Any ideas ?
Btw the pc is running XP 32 bit, don't think any other specs matter.
But now I'm stuck.
Any ideas ?
