- 26 Oct 2004
- Up North
Pretty much as the title really. Took the PC down to the parents over xmas and decided to format it as it was getting a bit slow, however i'm now having trouble connecting wirelessly. Pre format it worked great with very little problem, however now I only seem to be able to connect for about 10-15 secinds before it disconnects and then tries looking for a connection about 30 seconds later.
The PC is running XP Pro SP2 and I've installed the drivers for the usb wireless dongle, the router is a WRT54G. I know its a problem with that PC/Windows config as I bought a shiney new Vista Laptop over xmas and that works perfectly on the wireless network, any suggestions would be champion.
Cheers.
Cheers.
