I'm learning about sine, cosine and tangent waves so thought I would make some in Excel, so I typed in the angles from 0 to 360 in 15 degrees intervals. To give the sin values I used the formula =SIN(ANGLE*PI()/180) which works. I'm not sure why on 360, and in the cycles after so 720 degrees it comes up with -2.4503E-16 for 360 and -4.90059E-16 for 720 instead of 0. Also for 180 it says 1.22515E-16 instead of 0?
