- 8 Sep 2010
- Kent
Ok, so I have been inquiring over at the CPU sub forum about whether my CPU was acting as a bottleneck to my system. Had some really good help. This is the thread http://forums.overclockers.co.uk/showthread.php?p=19310522#post19310522.
As you can see, after fiddling with a few things, I have found that switching off crossfire when maxing out Crysis Warhead yields much better results (playable as opposed to unplayable), why might that be? I have the fully updated steam version. But I get nearly double frames with crossfire on shogun 2...
Also, you can see I have posted that my gpu usage with crossfire crysis:w is 60/90 respectively. What might be causing the GPUs to not be fully utilized? Is this a CPU problem or a psu problem? Or something else? Has anybody got any experience with the 1055t and this crossfire setup? Thanks in advance for any help you can offer.
