- 19 Mar 2020
I have a Leadex 850 Gold but the VGA cables which came with it have 6+2 then split to another 6+2 on the same lead. I'm using 2 lots of VGA leads on a Sapphire 5700XT but both have the this split to them which looks crap as its the first thing you see on the windowed case.
I can't seem to find just single 8-8 or 8-6+2 leads anywhere or is it just the case of buying the extension cables?
