Single Braided Cables
17 May 2012
I have a Cooler Master 750W Modular PSU and it has horrible cables. I've decided I want braided cables which I can plug into the PSU. I don't want extensions. Does anyone know if these exist or if it is only extensions?
Theese only work with corsair psu's. The connectors at the psu end differ between manufacturers. I have a set of those corsair cables for my hx850, they dont fit the antec psu in my other system.
Thats a shame,
i wasnt aware of that , i always use corsair PSU's .
Ill havr to get some myself then :D
Theyre pretty well made cables, though a little stiff and hard to route. I used them in my previous z77 setup.
Though the 24 pin cable there was a bitfenix extension. For the build in sig i got theese made up to match the mobo and fans.
