Single card that would match my twins?
15 Nov 2009
South east
got twin GTX 670 4GB's tempted to look into a single card replacement, Ideally would like to match my current performance which is very decent as I game on a 144hz 1080p monitor
I would like to keep nvidia if possible and keep the price as low as possible
I'm sure a single card now would beat one of them out of the water but the two together provide very good fps in games that use SLI well
I upgraded from 2x 670 2Gb to a single 970.
A 970 will be the cheaper option and is adequate especially at this resolution. If you have the money and want higher frames considering you have a 144Hz monitor then the 980.
Can't afford a 980 as much as I'd like too, I was also considering the 780ti given it has a wider memory bus and 3GB vram seems plenty for me at 1080p. 2nd hand on the MM would be a nice little upgrade ?
