Permabanned
- 11 Jan 2019
- bedlam
Case: Jansbo C2
Option 1: push
Option 2: pull
What is the best option?
i'm putting together a low power system for guy at works 7 year old, she play roblox/youtube..
GPU i5-4460
GPU GTX 960
is it best to push cold air in, the fan would half hit the GPU and half push into the case. the only exhaust would be the PSU fan / openings in the case.
i have a 140mm EK Varda sitting here doing nothing so was going to put that in, at 40% it makes little noise and move a good amount of air.
Option 1: push
Option 2: pull
GPU i5-4460
GPU GTX 960
