It will be very tight to do that with a Lanboy, they are very crampt cases, you also have to consider routing the tubing without kinking it, so the lanboy really is not too ideal for a watercooled rig.
I used to have a Super Lanboy and came to the same conclusion, they are a nice case but extremely tight on space (even for air cooling). The lack of airflow caused me temperature problems during summer.
The only way I can think of making water cooling work is by having some of the components and tubing (eg. radiator, pump etc.) outside the case.
