- 28 Nov 2008
- Newcastle
I currently have 2 9800gtx+'s and I'm upgrading my system I was unsure if I should put them into SLI or sell them and look to buying a single graphics card :/
Ive got the exact same dilema. Thinking of getting a 480 and keeping a 9800+ for physx.
why do people still bang on about the heat and noise of a fermi gpu, i have just gone from a 4870 to a 480, and to be honest it runs about the same temperature and is quieter than the 4870, i had the powercolor 4870 and under load was really noisy.
TBH, if you are planning to keep one of the 9800GTX+ cards, then you may be better off getting a 5870 instead of GTX480. You won't have the heat, noise and power issues of the fermi, but you will still have PhysX and CUDA support.
