25 May 2006 at 18:27 #1 Slinwagh Slinwagh Permabanned Joined 20 Apr 2004 Posts 6,034 Location Far far away.... Im about to embark on some watercooling, but I don't want to start hacking into my case to fit a dual rad. As Im only looking at cooling the CPU for now is a single rad up to the job? Thanks
25 May 2006 at 18:31 #2 Scoobie Dave Scoobie Dave Permabanned Joined 16 Sep 2003 Posts 2,901 Location Plugged into the Matrix Slinwagh said: Im about to embark on some watercooling, but I don't want to start hacking into my case to fit a dual rad. As Im only looking at cooling the CPU for now is a single rad up to the job? Thanks Click to expand... I would say yes. At the end of the day I first bought a 120.1 rad, then upgraded to a 120.2 rad, then upgraded to 120.3 rad But TBH a 120.2 rad is plenty good enough for cooling everything. I have cpu, 2x gfx cards and the chipset all watercooled. Just remember to get decent fans, like Panaflo 120x38mm fans as airflow is most important. Last edited: 25 May 2006
25 May 2006 at 19:00 #3 Cyanide Cyanide Soldato Joined 5 Mar 2006 Posts 3,975 Location Nottingham I've got my CPU and both GPU's all cooled by a 120.1 rad, so it'd be more than up to the task of cooling just the CPU
25 May 2006 at 19:57 #4 Mikebert4 Mikebert4 Associate Joined 14 Apr 2006 Posts 224 Location Peterborough, UK i've got CPU, Nbridge and GPU (mit pelt-although a small one) all on a 120.1 Rad... they said it wasn't possible... but i've not had a problem
26 May 2006 at 01:43 #5 Slinwagh Slinwagh Permabanned OP Joined 20 Apr 2004 Posts 6,034 Location Far far away.... Thanks for that.....time to spec some parts me thinks !!
26 May 2006 at 02:10 #6 locutus12 locutus12 Permabanned Joined 11 Mar 2004 Posts 5,884 http://forums.overclockers.co.uk/showthread.php?t=17580411
