Single SASdrive with P6T Deluxe
10 Jun 2010
Coventry
I have a P6T Deluxe and I'd like to use a single (not raid) SAS drive as the boot drive. Is this possible? I think I've tried every combination of applicable BIOS settings but nothing seems to work. If I boot into Windows using my SATA drive then the SAS drive is visible/useable once in Windows but I can't select it as part of the boot priority and can't install Windows to it.
Please help
I've sorted it now. For anyone else wanting to know the settings I used are:
In BIOS:
SATA Configuration - Compatible
Marvell SAS - Enabled
SAS Boot Rom - Enabled
In Marvell setup:
INT 13h - Enabled
Hope this helps someone. I also noticed that the drive doesn't detect if the time is 0. For me it's working at 2 fine.
