Single sided DDR400 512MB?
20 Apr 2004
When using two sticks of DDR400 double sided memory my motherboard (Asus K8N-E socket 754) will only run at DDR333. To run at full speed (DDR400) two sticks of single sided memory are needed or just a single stick of double sided memory.
Can anyone explain this to me and recommend some 512MB single sided sticks to replace the memory I currently have?
Single sided 512mb modules are few and far between, single sided means they have the chips down one side of the PCB.
The best bet would be to get a single 1Gb module if your budget will stretch that far.
