single slot card - around £120?
28 Jul 2003
South Wales
I need a single slot GPU to go in my shiney new sugo.
The reason being is that i want to fit a sound card and wireless network card in there and they won't fit with a double GPU.
Any suggestions?
Reality Bites said:
is it worth trying to stretch to the xt?
If you can afford the extra then yeah, but I don't think there's a single-slot version of the X1950XT.
This is an absolutely cracking bargain and it might not be on offer tomorrow.
I was looking for a graphics card for my Lian Li V300, so have the same issue as you, not enough pci slots.
I don't really need much graphics power so it's easier for me but I do have a tv card to fit in too. Which meant going for a USB wireless adapter, it may be a good idea for you, as it makes things a lot more flexible and the usb dongle can be hidden behind the pc. I still get good connection status and speed.
The x1950Pro seems to offer the best price/performance.
no reviews on it and i'm worried the fan would make a racket?
Herminator : i've had a usb wireless card delivered....but also have only just put a brand new PCI card in my desktop (the machine i'm replacing).
I may just bite the bullet and keep the usb one....i guess i'll only end up getting one if i upgrade in the future.
